re w210 radio wiring
2117kh
LIncoln U.K
r107 350sl
Hi every body..need your expert knowledge again
I am thinking of sliding in a Blaupunkt travel Pilot unit into my e320 to replace other ageing blaupunkt unit, cant stretch to command so this will have to suffice for now.
It says in installation destructions that it needs a positive feed from reversing light, wheel sensor wire and also speedo/gala (?) wire.
My queery is are these wires already in place in the wiring/plugs on the car. It looks like I have original radio wiring plugs in place.
any advice always appreciated
kh
npuk
London
A180 CDI Avantgarde SE (2008)
Car connections will be ISO. Speed pulse may not be at the ISO block so you may have to wire that in, see if you have a Green/Black or Green/Yellow at the ISO plug. Reverse signal wont be on the ISO.
OP
OP
2
2117kh
LIncoln U.K
r107 350sl
re iso wiring
Thanks for your advice, I will need to take a look in more detail of whats already there.
Do you know if you can buy the connectors to fit into the ISO plugs?
Also any body any suggestions on where to find a supply from reverse light although this is not essential apparently, it helps the travel piot to know when you are going backwards.
