Alright lads , have a bit of an issue with W211 e200 .
Have replaced rear pads : disabled sbc , dismantled callipers . pushed piston back in , went back like a knife into butter on both sides. Re assembled , put some copper grease on the pads . Enabled Sbc. Went for a spin - whistle from rear brakes after few miles . Pulled in and checked - discs blue , callipers hot on both sides.
Dismantled all back again to double check. Pistons moving ok , nothing seemed to be seized. Took vehicle for a spin - still the same...
Had an error C249F OPERATING TIME OF COMPONENT A7 / 3 IS EXCEEDED (SBC HYDRAULIC UNIT) on before replacing the rear pads , thought that could be the problem.
Have the error in sbc sorted now ( reprogrammed with star )...sticky brakes still there...
Any suggestions lads ?
