Rear diff heat sink...
John
Hardcore MB Enthusiast
UK
Skateboard
Do all E55Ks have a rear diff heat sink?
im sure its on all, mine does.
Mine too....
New, reinforced steel rear axle with differential cooling
The valuable experience gained over 35 years at the sharp end of car racing was a key component in the development of a power transmission system which features a larger cardan shaft, new steel rear axle with reinforced wheel location elements and drive shafts, and spring links made from a highly robust welded steel structure. The rear axle differential has cooling fins to lower the oil temperature by as much as 20 degrees Celsius.
Mercedes W211 E55AMG The most powerful E-Class yet | Mercedes 500SEC.com
