Petrol Pete
Hardcore MB Enthusiast
Hi
Sine I have had my car it had an annoying rust ring on one disc (see photo) it passed MOT and does not make a noise or anything but it looks carp. When I painted the callipers I popped the pads out and they were OK so it was obviously an old war wound from the first 100K miles before I bought it.
New discs are available from about £60 a pair but another garage 'mate' of mine said he wouldn't mind running his disc lathe over them as he has not used it for a while and had someone booked in later this month.
So anyway the photos show those of you who haven't seen one before what goes on. There are different types of lathes around but this type aligns itself to any hub run out (the hub faced is polished with a flap wheel first to get 100% mating surface) Once set and running the pass to RPM ratio is set by the lathe and the tooling runs in an orbital fashion so as not to cut grooves in the disc face. on non drilled it does both sides at once , on drilled it can only do one face at a time.
It took just one pass to clear the surface leaving the discs 21.45mm thick which is way within spec.
Interestingly when he bought this machine 8 or 9 years ago it was used a lot but he says the price of discs have dropped so dramatically in recent years (China ?) that it is often not worth doing from a labour/cost/reward.
But he says he has done a lot of pretty new BMW X5 and other 4x4's where the disc is captive behind the Hub (who knew ?) which are much more labour-intensive to remove even if the parts are cheap(ish) ££.
We put a new set of Akebono Ceramic pads in, Job done.
