Rear door lock fault
Qwertycls
Nr Perth
CLS250
The rear pass door on my 2012 CLS wont open unless I twice press the key fob unlock and then open the door. Anyone had similar and know the solution? Thanks.
Just one door?
It’ll be the lock itself, probably get worse and eventually not open.
Does this happen all the time or intermittently? Does the door pin pop up but the door refuses to open, from inside and / or outside? We have an intermittent one on our 2012 ML where the door pin pops but the door will not open from inside or outside.
The problem is consistent. Door wont open outside or inside with vehicle unlocked, all other doors work fine. But click the open button on key fob and the door will open on the second operation of the outside door handle.
I need to check on door pin, but doesn’t pop when trying from inside.
