Rear Lamps Blowing
lexuscol
York
W203 006 model
What is required to stop the rear lamps blowing?
Every so often I have a blown bulb and the car tells me it has gone to back up lighting. First one side goes and the following day the other side goes **** up.
Bulbs last about 6 months
2003 W203 C220cdi
TIA
Col
I'm curious to dismount the rear lamp assembly to see if mine is factory equipped with this!
Mine is a 2003 car, so not the newer
As there are 6 different 203 220cdi cars I just chose one in the middle. I could do a more refined search but it takes time.
Just put up the 6 numbers WDB203??? and I will do it all at once.
There is a similar mod for the 211 and the 220 I believe
thanks a lot television, I PM you directly the number
Marco
OK I have been to them all the 006,008,206,208706 and 708
When looking at the first one the 006 it says, it says later cars have it built in, so I go to the latest, the 708 and it says the same thing. The wording is unclear as to what cars have the mod.
The only guaranteed way is to measure the voltage on the lamps with the engine running, if the you have 13.8volts on the rear lamps, then you do not have the mod, they should have be least 1 volt under the running voltage.
203 tail lmps blowing
This should be sticky or in the DIY
Rear lamps blowing on all 203 cars
Fit modified cable harness Part number A 203 440 26 13 to off required
The cable harness just plugs into the original on the car
It generally only affects early 203's
Well that what it started out by saying when I checked, but it said almost the same thing on the late ones.
Thanks for that
The facelift models use different bulbs and updated SAM (fuse box). I changed all these parts on my car and there has been no sign of any problems. I also installed the matching rear harness.
Hi Miro, do you have the part numbers for the SAM and harness?
Col
