flt.eng
Beware.
I have just replaced the rear springs on my 211 E320 avantgared & would not advise any none professional, or more than competent person to attempt this job. Unless you have the use of an MB spring compressor. But if anyone wishes to, this is what I did.
My first attempt was by trying to remove the inner lower arm bolt but found this seized. (apparently 9 out of 10 are) I do feel that had this not been the case, this would be the best method. I then took Olly's advise & used his method of dropping the sub frame one side at a time.
Firstly I had the use of a lift, which helps, but feel it would be possible without, by useing stands.
I was told you only needed to remove the bottom shock. bolt . But found the shock. needed to be removed to give enough space to get the springs out. So this means removing all the boot trim to get to the top shock nuts. At this stage I was having regrets at starting the job. Anyway get the body on stands (lift or not) & remove the wheels. Drop rear ends of under body panels (to gain access to front subframe bolt) & place a scissor jack under the hub end of arm. Remove shock absorber. Pull all wires out of there retaining clips Now place jack under sub frame & remove the 2 sub frame bolts useing a torx e18 socket with a long handle. These bolts are loctighted in. Lower the frame as far as possible. This is where lack of knowledge & no diagram comes in. Firstly the fuel filler pipe stops the sub frame dropping enough. ( this is the rear offside first to be attempted) Consequently the spring did'nt want to come out with any ease & not knowing the make up at the top of the spring, it was'nt until I had levered the sring out that I found out it consisted of a spring cap a number of shims a top cup & worst of all a center locating pin which fell out on levering the spring out. This (plastic) pin should be held in position by a small captive screw in the chassis. There was no way I could get the new spring in position with the pin in place, so had to fiddle getting it back after the spring was in. At the moment I'm not happy with this But could'nt do any more as time had run out for the use of the ramp,& I still had the nearside to do. This side was totally different, the sub frame dropped much lower as there was'nt any restriction.
This nearside took about 30 min. as opposed to 2 hrs. for the offside.
I did take photos but failed in attaching, I do'nt think they would help.
I would not have started this job if I had known. If anyone says its easy they must be dealing with a different model.
