kg9
- May 18, 2011
- Location
- West Malling Kent
- E320CDi, C200 petrol estate. E350 sport petrol
You may recall my previous posts on this subject.
After checking relays fuses connections and voltage. Changing the pump, changing the dashboard switch the culprit was the SAM unit circuit board( situated and attached under the fuse box
A small connection had suffered some water damage so I append Isopropol Alcohol, and old toothbrush and hey ho
rear jets worked again
A bit if a faff removing the SAM . Incidentally Mercedes quoted £514.16 for a new SAM without coding
Hope this helps other members
