Rear wash wiper on w124 estate
michaelk3289
London
1999 W210 E240 Avantgarde
hi everyone
has anyone every heard of the rear wiper not clearing all of the window in its curve
the car had been left for several weeks, when i got back into it i tried to clear the rear screen only to find that the middle secton of its curve, if you imagine a clock on the rear window, it stops clearing and seems to leave the screen at about 11am and and doesnt clear again until about 2pm
any ideas
thanks
Michael
Pontoneer
MB Club Veteran
Central Scotland
'99 S320 W140
I think you will find the 'elbow' of the wiper arm is seized and needs lubrication . The arm is pushed 'out' slightly at the zenith of its arc and is not springing back in against the glass lower down .
The rear screen is not flat so the arm does need to spring in and out .
SilverSaloon
1994 W124 E300D Estate, 1985 R107 280SL
it may also be a little bit bent. mine was (if someone leans on the wiper it will bend it flat too much). careful re-bend may fix it
OP
OP
M
michaelk3289
London
i have sprayed some wd40 on the blade and the arm, seems to have worked, only a small area at the very tip of the blade and top of screen around 12 oclock position doesnt clear maybe will improve with use
thanks for info all
OP
OP
M
michaelk3289
London
after several days or rain and a little use the rear wash wiper is back to fully working, good old wd40
thanks for the tips
