rear wiper water leaking!!!
taumaan
South Hertfordshire
S203, 2007 C180K Estate, W204, 2010 C350 Saloon
hi all
help!! w203 estate 2007....no water to the rear screen so opened the tailgate..where the blue piping goes into the wiper motor, the connection has come loose....doesnt seem to click in place or anything....put it back in but it simply leaks when i spray water....
can i simply superglue the connector in place or do i need a new part..part no: 2038690187 apparently...
any advice please.
cheers
I have had this a couple of times now.
It seems to be a common problem so if anyone knows of a better fix than just shoving it back on I would like to know also.
Is that part number for a mod or just a replacement pipe?
leaking rear wiper washer
the chap at the stealership seemed to imply that this is the connector with a bit of tubing, i think....£4.50 + vat..........didnt order because want a more permanent fix ideally......
cheers
Still no luck with it then Rafiq?
