Nov 21, 2019 #1 L Lucio New Member Joined Nov 21, 2019 Messages 8 Location Windsor Car ML350 bluetec Hi all I have an issue with ML350 bluetec 2012 NOX sensors and I do not have a scanner to read the fault codes or reset the ecu. may ask your help in suggesting a reasonably priced scanner pls. Thanks Lucio
Nov 21, 2019 #2 BrummyPete Member Joined Aug 9, 2019 Messages 35 Location Birmingham Car Mercedes E220 I just used a Bluetooth elm scanner when I had an issue with my nox sensor, but in my case as the sensor was knackered it won't let you reset until it was replaced Sent from my SM-G975F using Tapatalk
Nov 21, 2019 #3 T TitusD Guest ECP streetwise thing will do it for £20. Again - it won’t clear the fault till it’s fixed though
Nov 23, 2019 #4 OP OP L Lucio New Member Joined Nov 21, 2019 Messages 8 Location Windsor Car ML350 bluetec Hi Guys I have used vGate adapter (wifi) and read two faults: -P2BA8: NOx Exceedence - Interruption of Reagent Dosing Activity (Powertrain, Generic) -P2BAD: NOx Exceedence - Root Cause Unknown (Powertrain, Generic) I'm guessing I need to change both sensors! Thank you
Nov 24, 2019 #5 MikeInWimbledon Hardcore MB Enthusiast Joined Nov 8, 2014 Messages 13,630 Car (Ex S211 E500, W212 E500, C216, S212 E500, W211 E500 5.5, W221 S500, S211 E500, SL500, S500, E55) To get the answer, I suggest that you post again, so that more can read the headline question about NOx readings.
