JOHNO978
I have stripped down, renewed and refurbished my front end steering and suspension incl ball joints and bearings...I am about to start putting it all back together could anyone advise me as to how much grease I should put into the Hubs and end caps...when I stripped everything down it was a little difficult to gauge how much was already in there...I dont want to go wrong either way...too much or too little...I have bought new Shocks...springs and Drag Link Assembly, Brake Backing Plates and all relevant ball joints...so I now have some pretty good spares to give away...as Follows..
2 front Monroe Shock Absorbers...done approx 3,000 miles
1 front coil spring.........................done approx 3,000 miles
1 front coil spring ( pitted but still intact and good for Mot)...miles ?
1 drag link assembly (passenger side inner link bent)
2 new track rod end ball joints
regarding the drag link...I dont know if it would be possible to remove the bent link and replace it...I have not tried it...but I do know you can only buy the full set up.
I shall be doing the same to the rear in a few weeks time and will definately have springs and shocks...they have only done 3,000 approx...Im just renewing everything to do with the suspension...same as the front,
these are off a Mercedes C280 W202 1996 Elegance...Location Wigan Lancashire....hope they will be of some use as I hate giving good stuff to the scrapman...and they could save someone a few pounds.....
