Red TPMS warning but pressures are fine
RM88
Newport
W204 C200 cdi
Last couple of days I’ve been getting a red check tyre pressure warning but the pressures have been fine at 35psi. I initially thought it could possibly be a bad wheel speed sensor but am I right in thinking that I would get an abs warning with that too?
Car is W204 2011.
Thanks for the reply but I believe I have the system which doesn’t have individual sensors in the wheels but relies on the abs/speed sensors at the hub.
As above, the ABS-based TPMS needs to be reset every time after you pump up the air in the tyres.
Again thank you for the replies. Double checked the pressures last night and reset the TPMS. Drove half a mile down the road red warning comes on. Re check the pressures, still at 35psi. If it was the abs sensor I thought I’d get more warnings i.e abs or traction warnings.
Do you get individual tyre pressures on the dash or an overall pressures guide. ?
Make/model/wear same for all 4 tyres?
Not the same brand on front and rear. Both the same on front and both the same on the rear. All on around 6mm tread.
