I have this problem too, as described, and also on the passenger front door, I cleared the drain hole but the problem remained.
If you think about the drain holes being blocked, as the cause of the problem, if the are blocked, then why would the suddenly unblock when you open the door.
If you open the rear passenger side door and run your fingers along the rubber seal, along the bottom right corner, you will feel a kink in the rubber seal, I believe that the water crosses over at this corner from the outside to the inside of the door seal, and so, when you open the door the water is released, just as you describe.
