reg plate bolts
Discussion in 'Bodywork' started by scooter, Aug 13, 2008.
  1. scooter
    scooter Hardcore MB Enthusiast
    174
    Jun 28, 2008
    NORTHERN IRELAND
    Car:
    mercedes 230te w124
    :confused:can anybody advise i have a e230te 91 the rear reg plate is bolt on and what i mean is bolt goes in through reg and into some sort of nut which is part of the tail gate itself the previous owner snapped a bolt inside the nut can the nuts be replace easily or does it need to be drilled out then replace:crazy:
  2. BaldGuy
    BaldGuy Hardcore MB Enthusiast
    4,305
    Jun 1, 2002
    Car:
    Cayenne Turbo + 911 + GS430 Sport
    Just changed the plates on my CLK and used really thick double sided tape.. I didnt want screw holes and like you one of the captive nuts has its threads stripped....
    The tape is about 10mm thick and works perfectly... Any good Car accesory shop who makes plates up will have it..
Tags:
Share This Page
