IMD
It seems that I'm not the only person who has experienced a very rough idle problem with my W124. I've recently bought a 1993 e220 estate. In Drive or Reverse, the revs fluctuate between 500 and 750, sometimes quite eratically, almost feeling like the thing is going to stall, other times not at all. In Neutral or Park, the revs raise to about 750 and stay pretty steady.
I took the car into an independant Mercedes specialist today and he ran a full diagnosis with the ECU, as well as spending a couple of hours checking over the car.
He has found that the regeneration valve is not working and this, he thinks, could be the problem, rather than the MAS. When he initially disconnected the vacuum lines from this valve unit, and played around covering and uncovering the tubes, the revs fluctuated in the same way. His suggestion is to replace this and see if it cures the problem.
I'll let you know what the outcome is later next week, after he has done the work. £75.00 including fitting seems cheaper than a new MAS!
