PaddyEnglish86
- Jun 8, 2015
- Mercedes W202 C250TD
Where can I get the remapped chips for a w202 C250td to put in myself? Thanks
Thanks but I'm looking for the actual chips that go in the ECU
He's got a w202 C250td...
There we go! Thank you!A lot of older cars did not use EPROM chips and therefore couldn't be remapped. The way it was done was to de-solder the PROM chip and then solder in a socket, program a new EPROM chip and put it into the socket.
I used to do a lot of older Honda's this way.
It's not that hard if you cut the pins and remove the old chip. you the remove each pin one by one. Use a solder sucker and be very carful not to lift any tracks.. I think they are surface mount chips with the solder sucker, fine solder tip remove one by one. The main issue they they are tiny legs and you would need to be skilled at soldering. Clean the board before and remove the flux from the board afterward.Depends, you need to be able to get into the ECU which will be sealed to make it water tight. You then need a good soldering iron and deolder suction device and be a dab hand at soldering in the socket. Once you have seated the new chip into the socket you need to be able to reseal the ECU ensuring it is once again water tight.
Not done an old Merc so no idea how the ECU is put together. Some cars are straight forward and screwed together with rubber seals, others are completely filled with resin to seal them. The latter can be next to impossible to do without damage.
If the ECU's aren't coded to the car (Some of the ones I used to do were coded to a separate security box) then just buying a second hand ECU and doing that is the safest way. Many of the chip programmers who do these do an exchange service which is probably the best way to go.
if that has not scared you off then good luck.
hiya
iam looking for a near to mint c250 td auto saloon w202 to buy if there is one for sale
contact me on 07703 448082
cheers
pete
