REMOVAL OF BONNET BADGE.
Discussion in 'Bodywork' started by REGGO, Feb 5, 2019.
  1. REGGO
    REGGO Hardcore MB Enthusiast
    159
    Jun 20, 2018
    S/YORKS
    Car:
    61 PLATE C220D
    Hi all. wanting some advice on the removal of the bonnet badge on my 2011 w204. currently it has the raised star gunsight style fitted and I am wanting to fit a flush one. I have noticed it hasn't got a nut and bolt fitting, but a sort of bayonet style spring idea. YOUTUBE shows the removal with a proper tool and one with a pair of pliers, has anybody used either of these methods and how easy is it. without damage.
    Bit OCD about breaking things. Cheers.:).:thumb:.
  2. Neiltodd
    Neiltodd Hardcore MB Enthusiast
    500
    Jul 22, 2009
    moray
    Car:
    c63 amg estate
    It is fairly easy to do without the special tool (if I managed it I reckon most can!)
  3. ash59fifty-uk
    ash59fifty-uk Hardcore MB Enthusiast
    3,163
    Aug 9, 2015
    The shire
    Car:
    W204 C63, Ford Transit
  4. moodi
    moodi Hardcore MB Enthusiast
    286
    Nov 4, 2018
    Bedfordshire
    Car:
    CLS55
  5. Headhurts
    Headhurts Hardcore MB Enthusiast
    1,051
    Nov 29, 2015
    Near Coltishall, Norfolk
    Car:
    Mercedes E350 Estate Night Edition
    On mine lift bonnet and under the badge is a plastic spring clip, just pinch together and push up.
    £39.50 for the genuine one seems expensive but I would buy genuine if I needed one.
    Robin
    Neiltodd likes this.
  6. Scoops1972
    Scoops1972 New Member
    9
    Sep 3, 2017
    Skipton, North Yorkshire
    Car:
    W204 C250 CDI Sport
    The spring loaded assembly simply twists around. A pair of pliers is sufficient on one of the lugs, as the only resistance is that of the spring. I used pipe grips/water pump pliers to get the leverage to twist. The emblem is mounted in a hole with opposing key ways (slots) so will not turn as you turn the spring loaded assembly. Fitting a new flat badge is even simpler, with the hole cleaned it can be located in the hole and simply pushed into place, with a satisfying click as the plastic spring lugs secure it. Just remember to hold onto the raised star emblem when you remove it, as it's a relatively heavy metal lump and could make a mess if it slid down your bonnet to the windscreen! Good luck.
    REGGO likes this.
  7. OP
    OP
    REGGO
    159
    Jun 20, 2018
    S/YORKS
    Car:
    61 PLATE C220D
    Cheers Scoops1972, going to have a go later when the weather brightens up.:thumb:.
Share This Page
