Remove boot lid trim from CLC?
Richatom
CLC350
Does anybody know how to remove the boot lid trim from a CLC?
I have removed the rearmost felt piece, which is just attached with those standard MB plastic pin fasteners. But then the next piece of trim is held in place with two hard orange plastic mushroom clips which I can neither turn, prise out or unclip. Any ideas?
I have done this to a CLC to replace the 3rd brake light, and I honestly don't know what orange clips you are referring to !!
It was straightforward, remove felt with pin fasteners, remove plastic sides, then remove plastic bottom section, did not need to remove plastic top section above the window.
I will have a look later for you again, to remind myself.
Can you explain "remove plastic slides"? That might be where I am getting stuck. I will post picture of the orange clips once my iPhone is charged up again (left it in the boot all day after taking the photos :fail).
I am trying to fit the wires for a reversing camera, so if anybody has any tips on CLC reversing camera fitting that would be helpful.
Here's a picture, taken from under the boot lid. It would appear that the piece of trim held by the two orange mushroom pins should slide forward to disengage from the pins, but don't want to apply to much force until I know what I am doing.
https://www.dropbox.com/s/6gb2xqe2lwddtur/IMG_2377.jpg?dl=0
Ah yes, just pull i think. You need a plastic trim puller to make it easy, and ease the clip rather than snap it. I think you can get your hand behind and squeeze it.
The sides, I mean the boot plastic sides, at the side of the rear window, where the hanger for the boot cover is. I think also they have a screw in them.
Disclaimer, if you break it, then not my fault :) Actually now I am doubting myself.
Well I went ahead and pulled apart the bootlid trim using mostly brute force and didn't manage to break anything. For anybody else wanting to fit a reversing camera to a CLC here are a few tips:
1) The video lead should go through the right-side cable boot. The left contains all the wires for the light clusters, so there is not enough room to get the video feed through it (took many hours to figure out that one!). The right boot just contains the FM aerial feed and heated rear screen, so there is plenty of room to squeeze the video cable through.
2) Start by dismounting the rearmost felt liner in the boot lid - just pull out the centre pins, then prise out the outer pins, and drop the felt.
3) Now prise out the rhs side trim panel. Just use brute force to prise it towards the centre of the rear window.
4) You can now drop the rhs of the centre trim panel. Undo one screw, and prise out with a big screwdriver the orange mushroom connector that I photographed above. Not totally necessary to remove the LHS of the centre panel - but if you want to do it you will need to mirror repeat 3).
5) You should now have access to the boot hinge rubber boot and can pull it off gently to get the video cable through it. Obviously you will need to use some sort of nylon puller cable, and a bit of detergent helps - but not too difficult.
6) You can now feed the video cable through the headliner and A-pillar. No need to drop the whole headliner - just pull it down from the rubber door and window seals. You can use a lot of brute force without breaking anything. Use a trim tool (or credit card, or plastic bicycle tyre lever) to squidge everything back together.
Hi
What camera have you fitted and how did you install it into the boot lid? Looking to do this upgrade myself but am abit nervous drilling into my car!!
Hi
This is the camera I fitted.
AMPIRE Farb-Rückfahrkamera, NTSC, Kennzeichen, gespiegelt/entspiegelt | KC502 | Rückfahr-Kameras | Rückfahr Kameras | Rückfahrsysteme
It is much better quality than the cameras that fit into the number plate lights, and it does not require major surgery to car except to drill a small hole behind the number plate holder to pass the camera cable. It is best mounted "upside down" as if mounted the "right way up" it slightly fouls the boot-handle.
