Remove console/dashboard of CLK w209...
Discussion in 'Interior' started by CLK2014, Nov 18, 2014.
  1. CLK2014
    CLK2014 New Member
    15
    Nov 6, 2014
    London, UK
    Car:
    Mercedes CLK320 w209
    Hi
    I want to put some carbon fibre features in the interior of my CLK w209.
    Does anybody know how to remove the dashboard (cover)?
    (Similar to the pic below)
    [​IMG]
  2. Nic55
    Nic55 Active Member
    168
    Aug 22, 2014
    Hertfordshire
    Car:
    W204 C63 AMG
    Open the ashtray as pull the gear lever section up towards you.
    Lift the shifter gator up and twist the little black screw and pull up.
    There are 2 x torx for the ashtray one each side.
    When ashtray is removed there is 2 x torx make sure you got for the outer ones not the inner one and that will release the center console.
    Make are you wrap the window switches, glove box trim and door trim. Done a full wrap on mine and looks really good.
  3. OP
    OP
    CLK2014
    CLK2014 New Member
    15
    Nov 6, 2014
    London, UK
    Car:
    Thanks for that!
    Did you do it yourself?
    You got any pics of it at all? (if you don't mind):thumb:
  4. Nic55
    Nic55 Active Member
    168
    Aug 22, 2014
    Hertfordshire
    Car:
    W204 C63 AMG
    Yes mate done it myself. Very time consuming but worth it.
    Take your time and don't rush it.
    Click on my username and load my old threads you will find some pics
  5. OP
    OP
    CLK2014
    CLK2014 New Member
    15
    Nov 6, 2014
    London, UK
    Car:
    Will do, cheers!:thumb:
  6. OP
    OP
    CLK2014
    CLK2014 New Member
    15
    Nov 6, 2014
    London, UK
    Car:
    Finally got round to starting it. Harder than it looks. Progress so far...
    [​IMG]
Share This Page
