Tekman
Ok so here goes I have placed this on engine bit and another thread
Car running fine service due so off it goes to Indy garage son`s he does service no issues , resets service, and of we go couple of days later Eml on did scan using Mycarly and Icarsoft MbII.
code said right air mass sensor foil exceeding limit so told it to delete and wait on Eml yep came back so took bat wing off found problem with seal to turbo replace then informed by member to replace Pvc valve did that orded new bat wing with Air mass sensors complete fitted today did scan and delete code using Icarsoft light goes off leave then come back and its back on scan with Mycarly same code delete drive then it comes back,
so if they are totally different sensors why is same code coming back and if its not being deleted how on earth do you delete it P133B00 upper limit value of component B2/7(right hot film mass air flow sensor) has been exceeded
C320 Cdi 2009 W204
Please please any help
C320 Cdi 2009 W204
