V8 Supercharger
Hello all
Thought id start a new thread for this. As some of you who may have seen my other thread regarding the rear shocker, it seems we might have been looking at the wrong thing and it might actually be the rear valve block thats the culprit.
Well, rather than chase down a shocker which i cant seem to get hold of i think il try and clean the valve block first and see if that helps.
As far as i can tell the valve block is just infront of the rear passenger wheel, there are 4 hose pipe connections, 4 electrical connections and a couple of nuts and bolts and thats about it, well obviously not as easy as that sounds but thats about the basics of it. Is there anything i need to do, especially in order to contain the fluid in the system?
Thanks.
Thanks.
