PJayUK
- Oct 6, 2008
- Location
- Surrey, United Kingdom
- ML320 W163, E320 W210 & Jaguar X300-XJR6
In order to change front pads and discs on a W210 do you simply need to remove the caliper carrier bolts (18mm I think) and then the small 7mm hex bolt to remove the disc? in other words there are simply three fasteners to change discs and pads?
Can the pads be changed without removing the caliper from the caliper carrier?
Sorry if these are basic questions but I am determined to do this myself and just want ti make sure I have all the info at hand!
Cheers!
Cheers!
