Hi all
I can't believe this is being such a problem must be a senior moment.
I need to get to the handbrake mech under the back seat because it is sticking and the warning light stays on I had a tip on the forum too lift the pedal with the foot as you release it and it works but it is obviously not a fix.
I can pull the seat up part way and then it won't tip forward anymore so cannot get to the part I want too,stupid Haynes manual as usual is telling me to remove caps and undo bolts but my seat has 4 what looks like hinges that should just tip forward. :fail
The Car is a W203 2005 without the seats you can split just one solid seat I have gone into search with no luck.
Cheers
Norman
Cheers
Norman
