removing tailgate lock barrol
SilverSaloon
1994 W124 E300D Estate, 1985 R107 280SL
hi
does anyone know how to remove a key barrol from a W124 estate tailgate lock? i have fitted a new (2nd hand) lock but need to swap the actual key barrol
thanks
derek
Derek ,
it has been a while , but if you remove the whole electrical locking mechanism from the tailgate , the lock barrel is held on only by two screws ( and is fairly obvious to remove once you have the assembly out in your hand ) .
Derek ,
Thanks Derek. I'll try this. The reason is I bought a donor car and swapped the tailgates round (as the donor had a brand new tailgate after a recent accident).... and as everything worked on it i just kept all the electricals in it, but the keys are different. i could just swap round the whole assembly with my old one, which i will do if i have to remove the unit anyway (as my car had a brand new tailgate lock fitted prior to my purchase from CI so probably better to keep with that if i can).
Is this unique to the W124 or is the mechanism similar on the W202 also?
