dogan124
- Jan 24, 2005
- Location
- Turkey-Ankara
- 1991 w124 300td (estate) & 1988 Golf II TD
Next month merc will be towing our heavy caravan while it is already loaded by family and packs. It is a well kept w 124 300 D estate AT.
I know on day time the temp indicator will sit slightly over 100 degrees line even on flat roads. Attempting AC or driving on hills will rise it to 110. (Cooling system is renewed other than coolant pump).
Can I expect a better cooling if thermostat is removed. Couple of times I had to start cabin heating to assist the radiator which definetaly helps.
I need some "cooler" methods to increase the cooling efficiency.
Any opinion?
Cheers.
Any opinion?
Cheers.
