removing whole lower rear suspension arm w124
SilverSaloon
1994 W124 E300D Estate, 1985 R107 280SL
hi
i have a bit of play in my rear lower suspension arm (the main big one).... i have a donor w124.
how easy is it to remove the arm from the car and refit?
can it be done without a spring compressor? i'm scared of w124 springs as i've heard horror stories...
i thought a jack under the arm, loosen the bolts on the end nearest the middle of the car and lower the jack and release the spring? reverse for the refit?
any ideas?
cheers
derek
grober
MB Master
Perth, Scotland
W204 C200CDI Estate
Much easier to do than the front springs- smaller and shorter for starters. Just make sure you have the car far enough up in the air to let the arm drop far enough- the spring will literally fall out. Use new washers and locking nuts.on the big inner bolt . They used to do an inner repair kit [ bush,bolt washers and nut] don't know if its still available. Can't comment on the outer end sorry.
kth286
Caversham Berks
E320 Coupe
there is also the roll bar link and damper bolts.
but all doable.
BUT, you say you have play !.
changing this arm will not remove play if it is in the multi-way bush in the bearing housing, which it is likely to be.
That needs a a special tool.
OP
OP
SilverSaloon
SilverSaloon
but all doable.
if i remove the arm will the bad bush be left in the hub? this is the only reason i want to swap round the arms - i was hoping the bushes are all part of the arm rather than the hub...?
nick.ged
midlands
mutty the nail; wide body amg 124 coupe
i recently changed both of my rear outer lower bushes.
the special tool i used was a big hammer and a suitably sized socket, both out an new ones back in, undamaged and perfect, in about two hours.
OP
OP
SilverSaloon
SilverSaloon
did you use a spring compressor? or did you just use a jack and carefully lower the arm?
cheers
derek
nick.ged
midlands
i always just use a jack on the rear for removal and refitting.
i use a spring compressor on the front for removal, but replace just with a jack, i have lowering springs fitted mind.
