MrGreedy
In regards to wheel refurbs, i have of good things from Lepsons.
If they were nearer to me, this is where I'd be going.
Gillingham!
I agree with this.
I'm sure care in driving also affects likelihood of damaging alloys.
Some people, and I'm speaking from experience as a regular passenger so I'm not going to name them, have zero mechanical sympathy. They slam on the brakes, drive over (rather than avoid) potholes, smash over speed bumps without slowing or straddling the narrower humps (whilst people in the back get shaken about like rag dolls), smash the clutch out on every gear change and crash into kerbs whilst parking.
I try to drive with much more awareness, am prepared and looking for potholes to avoid in good time, slow right down for and evenly straddle speed humps, have never kerbed an alloy and have opted for an automatic so said other driver can't smash the clutch and DMF to bits on my car.
When I have very tentatively tried to raise a casual observation on why (for example) the wheel on the other car has become buckled an needs to be replaced, I'm met with strong opinion and resolute belief that the driving styles are the same.
Absolutely I agree with you, I have anyways been careful when it comes to driving - over a speed bump, potholes, kerbs. My wheels got damaged when an a** from the other side was approaching and I had to move towards the kerb Caz he they wouldn’t give a damnYeah but no but.
I looked after my C43's but still found the rear 17 inch Monoblocs would buckle and sometimes crack on the inside.
Could you please elaborate further on this?
I take it back. Care in driving makes absolutely no difference to the likelihood of damaging or buckling alloys.Yeah but no but.
Oh dear. You've shot me in the foot there! A perfect example of not fit for purpose wheels dished out in their millions.Or in BMW's case the perfect storm of 1, £hite quality oversized wheels 2, £hite run flat tyres, 3, £hite drivers
With regards to monoblocks all sets are at least 15 years old now and the chances of getting a 100% straight set is zero.
Has anyone had an issue where the boss in the center of the wheel is thinner than the original and had to use spacers or shorter wheel bolts?
Sorry, I didn’t make it clear, I mean the part of the wheel that meets the hub is not as thick as the original wheel, and so the the shoulder of the bolt meets the hub before it has secured the wheel. So is the solution shorter bolts or a spacer and use the original bolts?centre hole should be 66.6 mm , not sure what you mean by thinner ?
Hi , Mercedes sorted out my diamond cut wheels and made a real mess of the procedure.Sorry, I didn’t make it clear, I mean the part of the wheel that meets the hub is not as thick as the original wheel, and so the the shoulder of the bolt meets the hub before it has secured the wheel. So is the solution shorter bolts or a spacer and use the original bolts?
Thanks for any advice.
Thats what gives you the offset , the wheels are therefore not designed for your vehicle tbh.Sorry, I didn’t make it clear, I mean the part of the wheel that meets the hub is not as thick as the original wheel, and so the the shoulder of the bolt meets the hub before it has secured the wheel. So is the solution shorter bolts or a spacer and use the original bolts?
Not uncommon that different wheels for MB come with different lengths of bolts. You should try the short ones but if those also don’t secure the wheel the only option are spacers. But then it means that those wheels are not for MB.Has anyone had an issue where the boss in the center of the wheel is thinner than the original and had to use spacers or shorter wheel bolts?
Can you even cut them twice ?Hi , Mercedes sorted out my diamond cut wheels and made a real mess of the procedure.
I won't have my wheels d / c twice so next time my tyres are changed I will have the wheels powder coated.
I would not temp fate and have fake wheels fitted to my car.
Not sure about the down under video because they have an interest to declare.
Hi , Mercedes re cut my wheels so powder coating next time.Can you even cut them twice ?
