replacement discs/ independent servicing
slkamg
I need to replace my front discs on my 2002 AMG 32 SLK. Any sugessions for good or bad? . Also is there a good independent Mercedes garage for servicing in the Leicestershire area? Thanks
I know its not the same model but I have just had some 'sport' drilled discs fitted to my CLK 500, they work great, much less fade and they look very cool ! They fit the original calipers and pads and where only £ 8.00 each more than the standard parts ! Dont know if they do them for your model though ....
Hope that this helps
Ident
I have recently replaced the disks on my clk55 amg.
What I found was that because it is AMG I was not able to find (nor did I want) any non MB parts.
I was able to source them from ECP though for cheaper than the dealer could supply them.
I would,however, check with the dealer first as you can then play ECP off one another.
Just had a look at ECP and your discs are priced at £157.78 each.
After some haggling with ECP I managed to get my disks down to £135 each from an original £167.
Oh, and welcome to the forum.
Maybe you could post some pics in the members gallery some time.
Mac.
Thanks, guys. still finding my way round this site. Will post some pics when I get chance.
