replacement Hirschman mast for a 124
mattc
Midlands
Audi A4, 1994 E320 Coupe, 1995 E300 estate
Hi
need a replacement mast as it will not go down the final section into the car body. Where can i get this please? Number on top of aerial is 04.
cheers
Ignore - have just found the HOWTO on this:eek: :eek:
Remember there are different Hirschman masts for different models. If its for your C124 coupe I believe its the same one fitted to the R129 H8 on the tip as its shorter in length compared to the H11 for W124 and W202 models. Check your existing tip.
top of mast says 04
