I'm currently in the midst of fitting the facelifted w210 (folding/dimming/blinking) mirrors onto my w202. As my car does not come with folding/dimming, I need to add these in and I’ve gotten the necessary switch and harnesses.
My w202 comes with heated front seats but I won’t be needing them in the near future as I’m taking it away to a warmer climate ( 30 C all year round ) hence I was thinking of removing the switches and putting the folding switch in them.
The problem is that I’ve tried removing the switches only to find out that it comes together with a busbar connecting the two switches leaving me with two holes on the console. I also found out that the ASR and the tilt/motion sensor switches could not work with the removal of the heated switches as some of the contacts are integrated to the busbar assembly.
So my questions are :
1. Is there a blanking plate that could be used to cover the additional hole other than putting another mod in?
2. Any way to overcome the ASR and tilt/motion switch not working? I’ve noticed that two connections at the bottom of each switch is missing due to the removal of the busbar assembly ( assumed that they’re the live and earth connection ).
I know the obvious answer is to place the switch at the OEM placement which is next to the mirror adjuster switch but I’m not confident with my dremel skills especially with prospect of bu****ing the install and the price of a replacement console.
Any help and pointer is greatly appreciated.
