To be sure, you could buy one from a main dealer parts counter (assuming you have standard wheels fitted.Had gearbox oil changed and they mentioned I have a wheel bolt missing. How do I go about getting a replacement and does it need to be fitted by mechanic etc.?
Hello and welcome . What car is it ? are you sure there is not a spare one in the boot ? When UK MB's were delivered they were fitted with lock wheel bolts at the dealership so most had the 4 non locking bolts left in the box the lock bolts came with in the boot , often buried around where the spare wheel lives (if you have one) or in a side panel in the boot.
Have a look around for a box like this.
Remember they are not all the same shape seat/shoulder on the bolt heads, some are radius and some taper, as well as differing lengths. Check you get the right one/sIf you dont have the bolt, then a trip to dealers, ask the guy at the parts desk (they are about 4 pounds), if you ask nicey nicey enough I am sure they will remove the wheel and re torque (using a special wrench) all the bolts for free.
Did you do recent tyre work, not often wheel bolts go missing.
Thats why the OP should go to the dealer who will check the part no based on VIN.Remember they are not all the same shape seat/shoulder on the bolt heads, some are radius and some taper, as well as differing lengths. Check you get the right one/s
I did have a tyre repaired last week and he mentioned too that one was missing. Will look in the boot in the morning to see if any are there where the spare wheel is. If not will pop to Mercedes to hopefully buy one. It's E270 CDI estate avantgarde.... Standard wheels I think.
