Hi Big J,BIG J said:I did buy a new spare key for my mums car (W210) from merc's had to program it myself which is quite simply, i'm not to sure about the ones on e-bay but i guess you may be able to reprogam them.![]()
ShinyF1 said:My spare key operates locks/doors etc but will not activate the ignition [or fire the switch like the live key as it nears the ignition keyhole]
Do I need a new one?
glojo said:Hi Big J,
Are you saying you simply walked into a dealership, bought 'blank' progammable key. Took it away and then programmed it yourself?
If so how?
I thought Mercedes-Benz have very strict rules about buying keys for the models we are talking about??
John the very curious
On the face lift E-class 210 there is NO key to cut that actually starts the car, it is a plastic key!! You cannot get it 'cut'!!BIG J said:I had a key cut and made but had to program it to my car, it was quite simply to program the key you put it in the ignition turn but don't start then take the key out and hold with the button down against the RVM leds for 10 seconds and its programed to your car.
I guess the ones on ebay may work as well if they are not programed.
glojo said:On the face lift E-class 210 there is NO key to cut that actually starts the car, it is a plastic key!! You cannot get it 'cut'!!
I am being very careful in my wording as a blanket statement will cause confusion. srowe has asked a question and we need to know the year of his vehicle?
John
Hi,srowe said:It's an 2000 X-reg E320, a plastic key that doubles as the remote. I have two metal keys for the door locks but what would be nice would be to be able to 'clone' the key itself.
There is a key "blade" that slides out of the plastic "key" housing but that will only unlock the driver's door, the boot and the glovebox. The blade has the keyring loop on it (so you can slide the key off your ring to give to the valet to park without accidently giving them access to the locked gloveboxglojo said:On the face lift E-class 210 there is NO key to cut that actually starts the car, it is a plastic key!! You cannot get it 'cut'!!
I took the batteries out of mine to look at them and it caused no problems with programming, my key is the same as yours.srowe said:Interesting. It depends how the programming is stored. If it's in volatile memory then taking the battery out might return it to blank mode. Has anyone had to replace the battery in their key? Do you have to re-program it?
Shude said:I took the batteries out of mine to look at them and it caused no problems with programming, my key is the same as yours.
glojo said:Hi,
Thanks very much for the update.
Ignore anyone that has suggested you can get ANY key from Ebay that can start your car! I simply do NOT believe them.
As far as I am aware you will have to contact your dealer, find out what means of identification\proof of ownership they need before they will order you a key.
Sorry about the bad news, but just think how difficult the car is to steal!!
Regards,
John
Hence my being careful in the wording. I think we are all fully aware of this 'key' and am I right in thinking it might sound off the alarm? I'm always concious about your pointing out my spelling mistakes whenever I submit a post and your latest contribution has cheered me up no end.Shude said:There is a key "blade" that slides out of the plastic "key" housing but that will only unlock the driver's door, the boot and the glovebox. The blade has the keyring loop on it (so you can slide the key off your ring to give to the valet to park without accidently giving them access to the locked glovebox).
I'm glad you used the word 'might'... I have read countless posts about what 'might' work. I have even read posts of someone that really knows someone, that knows someone who actually had an uncle that has done this.srowe said:Interesting. It depends how the programming is stored. If it's in volatile memory then taking the battery out might return it to blank mode. Has anyone had to replace the battery in their key? Do you have to re-program it?)
"Gone in 60 seconds", the remake with Nic Cage.glojo said:There was a film about car thieves stealing cars in a 24 hour period, but they failed on one specific brand!!!
