JOHNO978
Hi guys,Not been on here for quite some time due to health matters.I have been browsing for the past week or so as I have just put my C280 back on the road after 2 years.I have done all the work myself apart from the diagnostics needed to reset the ECU`s after installing new ABS/Speed sensors and the OVP relay.I was having an issue with "Surging" all the time so decided to clean out the MAF and the Throttle body, All went fairly easy untill I started the car, the idle speed is now leveling out at 1500 steady.I have no leaks at the throttle body nor at the Intake manifold switchover valve, all the vacuum hoses that came off during the job are back on and ok (I put bright yellow insulating tape on them so I could find them easily)...electrical connectors are all back on (Red tape on these). However I did notice that on the underside of the of the Intake manifold switchover valve there is a stubby hose,inside of this is a very small mesh insert...I removed the valve again and sucked on the little tube and the butterfly ? rotated a half turn as if it would allow airflow to pass it.I am wondering if there should be a vac hose on this ? I can only assume if there should it came off when I was taking it apart...but I cant for the life of me find it...any help would be fantastic as Ive no Idea where to look next or what the hose ( if there is one) would come from.I will try to post a diagrame that I have if that would help.
Regards
Steve.....
Regards
Steve.....
