fabes
On the (prior) E350, the centre box had corroded so I took the opportunity to remove it.
I had an X pipe fitted locally and was happy with the improvement in exhaust note when under modest or full load (even idle) - though of course I don't know what was possible....
Few said an X pipe was not appropriate for a V6 and in considering same for my E400 with the same engine (plus turbo) as the exhaust tone is under whelming, I have researched a simple stainless steel section insert, vs mild steel (which the internet says is better for a V6) vs H, X or even J pipe so to remove any drone although drone is supposed to only be an issue at 3 to 4 thousand revs and the car cruises at 2 to 2,500 rpm so would only in that rev range for a short burst and for a specific purpose (accelerating to overtake or put a smile on my face
i am not looking for a new exhaust and Longlife dealer in Southampton has an okay rep, but before I go and talk to them, my question is for those with a turbo charged car (V6 esp) did you have a simple steel insert replacement or did you go for a slimmer resonator, or an shaped pipe?
Any and all advice appreciated
