Restoring rust wheel arches
Chiefriley
1999 cle
Is it impossible.....
I have bubbling on all 4 now, I have no idea what the price would be...I'm UK based, but is it a hard DIY...I mean could I buy a hand held grinder, prep, etc. then spray myself...I'm not after perfection it's a 1999 320...just get rid of the bubbles and she'd look a lot sweeter...
Anyone done it...
Or know what I should pay
Thanks in advance...
A friend just had all four wheel arches done on an ML and that was £500 at "mates rates".
Are you planning to do the prep work yourself and then get the paint matched by a body shop or are you going fully diy?
I did a diy job on my W202 a few years back.
Have a search for DIY rust repair on hear, hopefully that will reveal something.
The rust on mine has come back now so needs to be done again. But well worth doing I feel, and not worth paying someone for if the car isn't actually worth much anymore.
Have a look on youtube it will give you confidence in doing it, get paint mixed to your exact shade (take car) at a car paint mix shop so it matches about £15 for a big can, in the shop they will sell you the right paper etc to use, good luck.
Thanks guys...really really appreciate that and it's given me a bit of confidence to give it a go, the prep work doesn't really put me off I think it's the idea the the paint won't match, but I intend to take my time, and pay good money for the paint...well at least that's the plan...
Thanks all.
Thanks all.
The reason I ask the colour because its extremely difficult [ but not impossible] to get an accurate match on a light metallic even with an accurate colour matched aerosol . Darker colours are much easier.
Thanks, well it's the azure blue I believe 366
So that's a bit more promising ; )
My w202 is azurite blue but rust free. Think i have one of the rustless ones. Just none anywhere. Sorry to rub it in. I wonder why some are really bad on all 4 arches????
Mercs in my experience aren't the best for being rust free, in fact they can also be "high maintenance", however, foolishly or not, I just like mercs. I never buy new so I avoid the cars built on a "Monday"!
If I wanted something rust free and "low maintenance" I definitely wouldn't have a merc. Tony no doubt is an exception
Unless the rust is tackled properly, it will re-appear. One tip- when you have removed all traces of rust, coat with fibre glass resin -just the resin. This will waterproof the repair.
If you DIY it will take a fair amount of time and you will be lucky to get a really good finish, But it will save a lot of money, and done properly should last a few years , and it will look better than the rust Its quite difficult to contain the respraying as the repaired area tends to grow, on my 202 I managed to contain it to the wheelarch and the flare, so the difference in colour is hardly noticeable as light reflects differently on the flared part of the arch . There is some merit in taking the wings off to get at the inside lip properly, if not you will spend a lot of time with your head inside the wheelarch.
