Restraint Sys Malfunction, ABS Run Flat, Cruise Control & SPEEDTRONIC inoperative
Discussion in 'Electronics' started by shanej77, Jan 8, 2017.
  1. shanej77
    shanej77 New Member
    3
    Jan 8, 2017
    Car:
    Mercedes AMG C
    Hello,
    I'm a New member and Just got a problem with my
    AMG c220 cdi sport Blue-efficiency 2012
    When i turn on the Car below error display on my dash
    * Restraint sys malfunction consult workshop
    * Abs inoperative
    * Active bonnet malfunction
    * Run flat indicator inoperative
    * Cruise control & SPEEDTRONIC inoperative
    Car starts fine but in few seconds i can hear a noise that i never head since last year from the engine (noise of a fan).
    Power steering not working.
    Front driver side headlight not working and passenger side day running light not working.
    When i lock the car front right indicator not working and instead of rear passenger indicator one of the break light flashing.
    Haven't plugged in to the fault code reader yet because its Sunday and if any one experienced this before any input will be helpful.
    Thank you.
  2. BlackC55
    BlackC55 Authorised Forum Sponsor Authorised Forum Sponsor
    18,772
    Feb 8, 2007
    Horndean, Portsmouth, Hampshire, Southsea
    Car:
    C43 AMG with a 55 engine and supercharger, E55 AMG, S500, etc
    You will need a Star diagnosis session. Using a Star will help with finding the issue.
  3. OP
    OP
    shanej77
    shanej77 New Member
    3
    Jan 8, 2017
    Car:
    Mercedes AMG C
    Thank you BlackC55.
    Update - Called up RAC and ask them to come and for some reason I gave the second key to RAC engineer. He opened the bonnet checked the engine and start the car. No errors and started without any problems.
    RAC engineer plugged his machine to read faults no errors message came up.
    I had a video that shows errors and RAC engineer checked it and said it's a communication error so take it to garage and check it.
    Drove it today 60miles without any problem with the second key ( touch wood).
    I will take it to garage for the star diagnosis but will it still show the errors on diagnosis?
  4. Lee86
    Lee86 New Member
    4
    Oct 22, 2017
    Cheshunt
    Car:
    Cls 350 cdi
    Hey there ! Exactly the same thing happened to me just now ! Car was parked on driveway for like a week . Came back from holiday to find exactly the same issues like you ! Tried it again a few hours later car was ok ..... but engine check light was on without any messages . Now it won't work again....starts fine but it won't even let me drive it because of PRESAFE thing . Did you sort out what the problem was ? Any one any ideas ? Thanks !
  5. PobodY
    PobodY Hardcore MB Enthusiast
    2,523
    Aug 23, 2016
    Stoke-on-Trent
    Car:
    CLK350 Sport, Nissan GTiR
    Any chance yours is low battery voltage? Maybe a battery on the way out (so it holds charge, but not as much is it should).
  6. Lee86
    Lee86 New Member
    4
    Oct 22, 2017
    Cheshunt
    Car:
    Cls 350 cdi
    Well on MB adapter it says the voltage is 14.3V .... just now i managed to start it again without any errors but it comes with check engine light up....
  7. singhengr
    singhengr New Member
    3
    Feb 11, 2018
    West London
    Car:
    E Class W212
    Hi
    Can you please advice what was the actual problem. I am facing similar issues.
  8. singhengr
    3
    Feb 11, 2018
    West London
    Car:
    E Class W212
    Hi
  9. Lee86
    Lee86 New Member
    4
    Oct 22, 2017
    Cheshunt
    Car:
    Cls 350 cdi
    Battery issue ! Replace your battery and everything should be ok .
  10. singhengr
    3
    Feb 11, 2018
    West London
    Car:
    E Class W212
    Hi Lee
    Thanks for the swift reply. I have already replaced both batteries and Left bonnet actuator but this has not helped so far.
    Lets see if Shanej77 had any different diagnostics.
    Thank You
  11. Lee86
    Lee86 New Member
    4
    Oct 22, 2017
    Cheshunt
    Car:
    Cls 350 cdi
    Sorry to hear that .... it worked for me . Hope you gonna sort it out quick !
  12. Wynner
    Wynner New Member
    1
    Apr 30, 2019
    Ireland
    Car:
    E250 w212
    Hi guys. I have similar problem today. Did you ever get to the bottom of this. Any help appreciated.
  13. StanleyN
    StanleyN New Member
    2
    Jun 9, 2019
    Donegal
    Car:
    E220 CDI Avantgarde
    Is this really a battery issue only? I have the same errors in the same order. Did anyone ever get to the best solution for this problem?
  14. StanleyN
    StanleyN New Member
    2
    Jun 9, 2019
    Donegal
    Car:
    E220 CDI Avantgarde
    Hi, was it just the main Battery or both if you have 2. I have a small battery in the boot but I have not tested the voltage.
Share This Page
