Retro Fit
mercman1969
Hi all,
Have ordered a new MB B Class but did not opt for either the pre wire or sat nav
Is it possible to retro fit either of these items as an after market?
ideally really need to be able to use the phone on the move
Any advice greatfully receieved
Regards
Pete
mercman1969 said:
Hi all,
Regards
Pete
All options can be fitted. Precisely how much do you think it will cost because I am confident that it would have been cheaper ex-factory.
Take for example the A-Class W169, the navigation unit for that car is about $3400 Euro. Then comes the other items you requested.
For a Nav + Phone install you would be best off with the proper wiring to the overhead antenna. The phone install will be quite expensive as the items are spread all over the car and as a result the amount of dismantling is excessive. IF you do a job like that in the UK you will be alarmed.
Enjoy your trip to the Netherlands.
