Hi everyone. It's my first post on here and hope you can help me
I have bought a set of retrofit running light/indicator strip and now need to work out how to wire them in.
The red wire needs to connect into the positive for the existing running light and the yellow onto the positive for the indicator and the black cable into neutral.
I can't find a wiring diagram which shows which wire is what on the loom which connects into the back of the headlamp unit.... Can anyone help? My assumption is that this is the best way to wire these in (?) if it isn't then any advice you can give me is much appreciated.
I have added a link to the lights below. They look great when I test them offline
a.aliexpress.com
Cheers
0.33£ 94% OFF|Daytime Running Lights | Led Running Lights | Brake Flow Lights | Auto Headlights - Signal Lamp - Aliexpress
Smarter Shopping, Better Living! Aliexpress.com
Cheers
