Rev Counter
Discussion in 'Engine' started by Shaun's C280, Jan 8, 2009.
  1. Shaun's C280
    Shaun's C280 Active Member
    83
    Dec 14, 2008
    Weedon Bec, Northampton
    Car:
    1996, W202, C280 Elegance Auto
    Stopped working this morning for some reason??!
    Got into the car and the temp guage, fuel guage, speedo and rev counter where giving no indication, drove a mile or so and all the others responded but the rev counter is still having none of it?
    Is the cluster on its way out or is it worth having a look at the sensor? Is it mounted on the gear box?
  2. Ian B Walker
    Ian B Walker MB Enthusiast
    7,672
    Jun 7, 2003
    Freckleton
    Car:
    300-24, saloon and coupe, E300 24 valve diesel estate
    Check your OVP relay as these have been known to cause your problem
  3. OP
    OP
    Shaun's C280
    83
    Dec 14, 2008
    Car:
    Thanks Ian :)
    I take it this is located either under the bonnet, under battery cover, or in with the fuses?
Tags:
Share This Page
