Rev needle up and down!
nickiandboris
S211 Rev needle up and down!
Hi Guys,
Another day another problem, I have a 53 plate E220 CDI 115,000 miles and I notice the car rocks back and forth at around 30mph and again at 50mph(feel sea sick :eek:). When it does this the rev counter needle is moving back and forth and not staying constant:confused:. I have checked the car and it doesnt have the dreaded Valeo Rad, I took it to an Indy at the weekend(not about this fault) and there was a very slight oil leak from the gearbox electronic plug(this didnt seem to concern the indy due to the slight amount) Any ideas>?
You have some sort of irregular running fault. A check witrh a star should show up the cause. It is probably an injector issue
Thanks BlackC55,
If it is an injector issue is that an expensive job?
Not really.
£150 for an injector plust a seal, bolt and fitting
