Hi guys,I fixed my reverse camera yesterday but unable to remove the air vent to be able to get the radio out.one side came off but the steering wheel side not coming off, bought kits from sune
2010 C350 CDI Sport sold , 2015 E250 CDI AMG Line Sold
If you have a w204 you need to take out the 4 little rubber bungs around the vent then I used a small Allen key you put it not the hole and turn it 90 degrees this then grips the vent then you give it a pull BUT you only need to put it out about 5mm on each one then pull it fully out with just your hands. If you need the correct tools look on eBay
Oh the facelift w204. I don’t know for sure but if it is like my e class the whole strip comes off (from about the glove box right along to the edge of the air vents) have you done a search on YouTube just to confirm?
I took the Radio out of my E500 which is a pretty similar process. Once the air vent is out just make sure you don't drop one of the brackets for the Radio and and Torx driver down inside the car ... ask me how I know!
Thanks paul.it was difficult to remove the air vent.I managed one side but other side not coming out.Scratch my air vent a bit.I took it to audio shop and was fixed yesterday.thanks a lot
