Hi All,
I recently discovered that the left and right audio channels are reversed (left channel content comes out of the right channel & vice versa) when playing music from my iPhone. I've had my car over a year and never noticed until I added a track with very noticeable placement of instruments!
I visited my local dealer who wasn't overly helpful and then went on to try to get me to book in to pay for diagnostics which I am not prepared to do as this is obviously a physical error somewhere and not a fault that has just occurred.
I have also tried playing audio through the 3.5mm jack adaptor cable and this too is reversed. Having looked into the connections in the interface cables, the audio line-in to the car uses a different connection on the glovebox socket for the 3.5mm jack lead and the iPhone cable, so I'm now leaning towards the fault being on the car side rather than the interface cables as it's less likely that they are both incorrectly wired.
In the meantime, I have now opened up the connector on my iPhone interface cable and physically swapped the left and right channels over to correct the problem! At some point I will pull out the head unit and investigate further, but I am just wondering if anyone else has had this problem?
