msc56 said:Has anyone retrofitted a reversing camera on a facelift w204 with command system. Has this worked ok? The dealer advised me that I should not have it done by third party outfits as it can cause a lot of side effects.
That is nonsense provided the third party knows what they are doing. Comand.co.uk, who are also members on here, know far more that dealers do about retrofitting. They have previously fitted all sorts of electronic factory mods to my cars and many others on here and are the only place that I would let dismantle my car. They are in Lightwater in Surrey but it'll be worth the drive to know that it will work properly.
msc56 said:The dealer advised me that I should not have it done by third party outfits as it can cause a lot of side effects.
Side effect is it hurts the dealers profits:fail
Mine cost less than £30 total and a couple of hours out of my life..
I have factored in that it is a cheap camera but the quality on the screen is perfect for what I need and if it goes faulty I will just buy another 1
Hardest part was removing command system but once you have done it its really easy..
I take it that one needs to thread a cable from the boot to the command system. This must be a nightmare to do as it needs to go under the carpet and into the dashboard. Any suggestions?
Is there a trick to getting the metal trim out from the the middle air vents ?
I plan on installing mine soon as soon as the adaptor cables arrives and this is the part I am most worried about.
there is a youtube clip of someone installing a camera to his car. Seems fairly straight forward if you take you time
Hi Beno, I plan to follow that for the installation of the camera and setting the Comand.There's a really good youtube video to follow an Aussie guy takes you through step by step. I used them to fit the camera very easy takes a couple of hours.
