Reversing camera problems
V8ed
Ml63 AMG
Hi I have a 2007 w164 ml63 with a factory fitted reverse camera. However it has never worked, only occasionally flashing green when engaging reverse. I've pulled the back tailgate trim off and played with the connections but to no avail. Has anyone got any advice on how to trace the fault? Thanks.
Cable goes through back door loom (left) to the voltage converter (which is on boot floor, but visible through if you remove the trim cover on left in boot, and then coax runs from there up to front of car.
I'd suspect the boot door wiring loom or poss the voltage converter if its got wet - possibly the camera if its got wet too.
If you are near Lightwater in Surrey, we have spares of all parts at Mercedes Retrofit Specialist - Comand.co.uk and can work out whats wrong for you
R
