reversing camera
djtl
Oxfordshire
Vito Dualiner 111
I am fitting a reversing camera and i need a live feed from the reverse and an earth what are the wiring colours for reverse and ground on the cluster plug ? thanks
Get someone to engage reverse while you are at the rear of the car with a circuit tester and check for the wire which energizes the reverse light bulb
You mean at the rear light unit plug? I'm guessing: white/blue wire (not sure if this is the correct Vito).
Not sure if it the same but on my C Class it was the blue / grey one.
Are you connecting it to a COMAND unit? Post up pics of the result, I want to do this at some point.
