Reversing light wire colour ??
KennyN
Paisley
Me - BMW 440i Coupe / Dog -Cayenne
CLS facelifted W219 , 2010 model.
I am needing to tap into the rear right light cluster connection to power my reversing camera and before i go mental with my MM sticking it into all-sorts of places does anyone know what colour is the wire is that feeds the reversing lamp , it has the factory LED light clusters if that makes any difference.
Thanks in advance
Kenny
Thanks in advance
Kenny
This probably wont help much as mine is a W211 E-Class but it was the solid yellow on mine.
I would recommend checking with a multi meter anyway as I was told it was all sorts of colours which were all incorrect! I just checked all the wires at the main connector block on the back of the light cluster. As I didn't have anyone with me to check the voltage whilst I put the car in reverse, I used my phone to video the multi meter display and played it back afterwards!
Mine was yellow too.
Can I recommend you use a relay too for a clean feed. Depending on what camera you're using you may get some interference if you don't.
Which is exactly what has happened , clear screen with the car off (obviously) but lines with the car running .
Off to Halfords now for a relay :doh:
Kenny
Relay now fitted , image quality is as good as the factory fitted one in the wifes Juke.
All cables now tidied and just have to decide the best way to mount the camera , it will either get screwed onto the bootlid or bonded onto the back of the registration plate which will save drilling two extra holes.
Kenny
Hi Kenny
Appreciate it was a long time ago but what relay did you purchase as i am currebtly having exactly the same problems as above
Any information would be greatly appreciated
Edit
Kenny
Hi Kenny
I have quoted Kennys post so he gets a notification :thumb:
