Should I be concerned?
This appeared for the first time while I was making a right turn..When I got home I tested it by turning wheel full right and the lights appeared to be fine? see attached pics.
It’s a separate H7 halogen bulb in the headlamp itself. Look closely with the lights off and it pokes out at an angle between the dipped/main beam housing and the parking lamp LED.
Access is at the rear of the headlamp, it’s a twist in bulb holder.
