Right-Hand tail lamp / brake lamp
Discussion in 'Electronics' started by Ravs88, Jan 14, 2019.
  1. Ravs88
    Ravs88 New Member
    6
    Jan 14, 2019
    West Midlands
    Car:
    C204 C220cdi
    Hi all
    New poster here. My car is a c204 c220cdi.
    A little puzzled as the bulbs have not gone...
    Driving home yesterday and got this error message "Right-Hand tail lamp / brake lamp" message. Any idea?
    The bulbs seem to be ok, the connections too and bulbs have not blown. The bulbs holder has not burnt/ corroded away as I have read somewhere. Any ideas
    Ravs
  2. whitenemesis
    whitenemesis MB Club Veteran
    15,583
    May 7, 2007
    Car:
    Lexus RC300h F-Sport 2016
    Have you checked with the brake pedal depressed?
    Be aware MB uses a substitute lamp should one fail
  3. Benzowner
    Benzowner Hardcore MB Enthusiast
    2,539
    Jun 21, 2004
    Bristol
    Car:
    B180 CDi W245 in Silver
    Had a similar issue with my old E Class and found it to be a dodgy bulb. I foolishly replaced earlier with a cheap bulb not good quality bulb.
  4. st13phil
    st13phil MB Club Veteran
    7,211
    Nov 6, 2007
    North Oxfordshire
    Car:
    His - Denim Blue A220 AMG Line Premium / Hers - Obsidian Black R172 SLK55
    Most likely this ^
    For example, if the tail lamp fails, the car runs the brake lamp at low power to provide tail lamp illumination.
    whitenemesis likes this.
  5. OP
    OP
    Ravs88
    Ravs88 New Member
    6
    Jan 14, 2019
    West Midlands
    Car:
    C204 C220cdi
    Thanks for your help.
    So what are you saying is one of my bulbs is failing , and on this occasion my brake light bulb which needs replacing for and good quality one?
  6. st13phil
    7,211
    Nov 6, 2007
    North Oxfordshire
    Car:
    What I'm saying is that the most likely cause is that one of the bulbs has failed so you should pop them out and give them a proper check. When you say that "bulbs have not blown" is that by examining the filaments / checking with a test meter, or that a lamp is seen to illuminate?
    If you find a filament blown (typically it's one of the two in a combined 21w/5w stop and tail lamp) then replace; if all is well with the bulbs then you will need to look elsewhere.
Share This Page
