Drove the car this morning and almost straight away got a strange sound from the rear, it was almost like the clicking you hear when car panels are cooling down after driving on a hot day, but much deeper and louder and with an echo (whatever it was was in an enclosed but empty void). Every small bump I drove over was accompanied by the same 'click' until one bump caused an almighty bang from the back as the roll bar engaged and the hazard lights came on.
Tried resetting the roll bar by pressing the button on the dash, but after research it appears that button is just to lower the rear headrests when they've been raised manually. I then discovered how to insert an Allen key/screwdriver down the side of each headrest to release a spring and push the headrests back down. I tried this as indicated but couldn't locate the spring mechanism, let alone try and get my arm between the headrest and the roof to try and exert enough pressure to try and force the headrest down (apparently it takes a great deal of weight).
I then rang our local dealer who said the car would need hooking up to diagnostics to be reset and would cost nearly £100.
Has anybody else had experience of this? The resetting doesn't overly worry me but the preceding sounds make me think something broke, which sounds expensive!
